 XStream Clone - Well not quite a clone...
ShelGame Posted - 11/02/2015 : 06:21:08
Been sketching this for about a month now. I had decided that after the prone, I wanted an actual recumbent that I could ride long-distances.
I've given up on the prone, an am now pulling-ahead this project to this winter.
Most recent drawing:
I like the look of the X-Stream, but also the Reynolds Nomad. So, I tried to take the basic tubular frame design of the XStream, but dimensions more like the Nomad -- Lower seat height, and more slack heat tube angle, slightly longer wheelbase.
I no longer work in the same shop with the very talented professional welder that did up the aluminum prone frame for me; so, this one will be fillet brazed 4130 steel.
Cut wood for the jig this weekend. New Oxy/Acytelene bottles should be delivered this week, along with the 1-1/2" x 0.035 tubing for the frame. I already have the drop outs, bottom bracket, and mid-drive I've collected over the years.
Jig board still needs legs to get it up to working level.
ShelGame Posted - 07/15/2018 : 12:11:56
Just gave it a quick test ride around the block, and I think I like it - a lot. The steering Is a bit heavier, but itís also much more on track (probably due to the very long trail. When it turns, it wants to Ďdive iní to the turn. At slow speeds, thatís not such a good feeling. But, at higher speeds I think it will be fine.
I think this is now my primary bike for Northbrook. Iíll bring the F5, too. Just in case.
ShelGame Posted - 07/13/2018 : 21:11:30
Visibility is greatly improved with these. Should be much lighter, too. Hopefully get a test ride around the neighborhood tomorrow.
ShelGame Posted - 06/18/2018 : 08:49:50
New and improved (lowered) handlebars coming up! Took maybe 2" off the top; really cleaned up the cable routing. And, these shifters let me move the grips about an inch closer together.
Jerry Posted - 05/30/2018 : 20:28:36
Looks good and fast! Nice work.
warren Posted - 05/30/2018 : 17:45:33
Wow, that's pretty laid back now! It should be fast once you get the HBs worked out.
ShelGame Posted - 05/29/2018 : 11:00:47
It's rideable. Wheel flop is there; but, manageable, I think. This bike is way more comfortable on bumpy roads than the F5. Feels faster, too. But, that might just be because it's lower to the ground.
It'll need better tires, and I think I need to re-do the handlebars to clean it up. I can't see a damn thing through them with this setup.
Need to move the wheel covers from the Stratus over to this bike.
ShelGame Posted - 05/26/2018 : 16:30:17
Assembly potion of this experiment is done.
New specs are:
71" wheelbase
30.25" BB
20.5" Seat
17.5deg seat back
62.5deg HTA
4+" (!!!) of trail
Now, to try and ride it. I'm a little worried about wheel flop with remote steering. We'll see. Maybe I'll have time for a ride around the block tonight after dinner.
ShelGame Posted - 05/24/2018 : 13:47:06
I'm going to try something with this bike this weekend. Dual 559's. I have a fork I got for the ActioBent and never used, 2 559 disk wheels from a parted out MTB, and a pair of skinny 559 tires (actually, wheelchair tires) also from the ActionBent.
This should raise the BB 2-3", and lower the top of the seat about the same. Maybe lift the seat bottom an inch or so. It will get the seat angle down to ~20deg even, but also slacken the HTA to ~ 63 degrees.
I'll sketch it all up before I fit parts, just to make sure the steering geometry isn't something stupid. But, it should make this bike much more aero. And, I already have rear wheels covers to fit the 559.
ShelGame Posted - 11/07/2017 : 09:55:24
Originally posted by Speedbiker
How about moving the front wheel back and Zing the frame a little?
Like this?
Thought about it. Right now, I have a fascination with 'stick' bikes. So, I was seeing where it could go; how low you can get the seat, and what it would look like.
I actually have a Rans F5 steel frame coming today. I'll probably play with that first for a while and see how I like it. Then decide what to build next...
alevand Posted - 11/07/2017 : 05:29:49
Looks like a Bacchetta.I made a bike once with the BB that high, seat was much lower, 15 inches, I would fall over at stops, trying to get my leg up that high to start, with an up hill grade. With the seat that high, you can walk it first to get rolling, then bring your legs up, so your tiller should have a pivot, so you can sit up. The forward bars makes that easier, to pull up on. Of course if its just for racing, its fine.
Speedbiker Posted - 11/07/2017 : 00:30:52
ShelGame Posted - 11/06/2017 : 21:43:17
No Z. This is just a first sketch. Literally did this last night in a hour before bed. Really just a geometry study at this point. Feel free to poke holes in the idea.
Speedbiker Posted - 11/06/2017 : 18:55:25
Sounds good. I assume the frame will have a slight Z?
Jerry Posted - 11/06/2017 : 17:47:13
I have a high racer, mid racer, and low racer. The mid racer is a Catrike Musahi and handles like a very expensive sports racer. The high racer is a hand full sometimes in traffic and high cross winds. The low racer you need to pay attention at all times. If I were to build my own, it would be something like the Musashi. It is very fast and nimble. The seat recline is not 10 degrees, but that can be worked out. Good luck with whatever you choose.
ShelGame Posted - 11/06/2017 : 13:52:08
Then a low/highracer!
Getting closer!
I worked on a sketch last night. I'll post it in a new thread later.
But, briefly, I'm looking at a 700/650c 51" WB, RWD stick bike capable of a 10deg seat angle; and with a fixed short boom BB; 23" seat height, 30" BB height.
What I'm not sure of is, the relative strength/stiffness of the main boom that long as a monotube. It might need to be a truss frame in steel.
Speedbiker Posted - 11/06/2017 : 12:26:52
ShelGame Posted - 11/06/2017 : 09:21:14
Originally posted by carolina
Yea shelgame, build a low race bike like sb said. This build is incredible, look what you know. Class A+. Maybe two 20Ē wheels racer.
ó
I have something in mind, but I'm just not into the low racer thing. Yet.
carolina Posted - 11/06/2017 : 09:09:28
ó
ShelGame Posted - 11/05/2017 : 18:17:43
How about leaving that sweet bike as a tourer and building a race bike? You know you can!
You might be onto something there, Thom...
Speedbiker Posted - 11/05/2017 : 10:47:49
ShelGame Posted - 11/05/2017 : 08:11:08
Originally posted by warren
How about 26Ē wheels? They have a very large selection...
Large selection, yes. But, generally not in road type tires or rims. Itís hard to find rims narrower than 20mm. Actually, 20mm would probably be OK. But then finding tires seems difficult. There appears to be more available tire-wise in the 650c (571) size.
warren Posted - 11/04/2017 : 23:00:09
ShelGame Posted - 11/04/2017 : 18:46:40
OK, currently, the lowest I can get the seat with the 700c on there is 26.5deg. If I go with a 571 wheel, basically I can lower the seat 1". But, that only gets me 1.5deg lower; down to ~25deg. Now, 1" lower is of course going to be better. But, is it better enough to justify the wheel change? I'm not so sure.
I couldn't find any decent tires in the 559 size, that's why I was looking at 571. 559 would get me only another 1/4" lower.
I really need to lower the top of the seat 2.5" to get down to 20deg. Not sure I can get there with this bike.
Johnsfwdbent Posted - 10/29/2017 : 20:17:24
Depending on your wheel base you might gain 1 1/2 degrees changing to a 559 rear tire thatís what I gained on my MBBLR.
But that would give you room to rotate your seat back 3 degrees or more depending on where the tire would rub the seat.
I say go for it, you will notice better aerodynamics.
John
ShelGame Posted - 10/29/2017 : 18:15:32
Had another thought today while staring at the bike...
Right now, the seat is at 25deg, and canít really go any lower - with the 700c wheel. If I go to a 559, I calculate I should be able to get the seat angle down another 10 deg. Iím not sure it will really go that low, but I think it certainly will go to 18 or 20.
So, does the more reclined position outweigh the loss in rolling resistance of the slightly smaller tire? My guess is yes.
