 Velomobiles!
Terry Posted - 11/02/2017 : 12:52:10
New poster here. I have been playing around with home made Velos for a few years.
I have had much help from members like ricmantoo and more recently Garrie Hill.
My interest is wood composite .the first Velo designed mostly by Rick turned out pretty well and I am now attempting to copy a WAW.
https://www.flickr.com/photos/146970675@N08/shares/tf8K02
I usually have lots of questions about Velo construction and bike stuff? but I do have a pretty good background in wood composite projects,so I like to help out interested parties where I can. Computer workings is definately NOT my strong suit! I hope these links to pics work , I am still trying figure all this out!!!
I have resisted posting before to this section as it seemed to be going in odd directions with old odd stuff!? For awhile I thought there was a hint of satire? Anyway, if a section is supposed to to be about velomobiles then I better add my 2 cents!
Terry
carolina Posted - 07/02/2018 : 21:45:41
Update Terry?
Terry Posted - 05/28/2018 : 19:53:52
Still a work in progress.
carolina Posted - 05/28/2018 : 15:35:28
How bout boom pic???
Terry Posted - 05/28/2018 : 09:45:31
https://photos.app.goo.gl/GnyqWTuctLfgZgt23
Some progress albeit slow!
I've settled on a chain line similar to the Quest. One idler on power side and a tube for the return line.
I need to rebuild the the tunnel and the bridge and the rear chain cover. but that is relatively easy .now that I can see where the chain will run!
I have most of the parts for the front suspension and the steering.
I am still hopeful I can use centre tiller steering for this build.
carolina Posted - 03/31/2018 : 10:08:28
This might have been posted twice, it popped up on youtube now.
https://youtu.be/POymJS6_e6I
carolina Posted - 03/16/2018 : 08:42:51
Think about the sliding bb from theo. Velomobiel.nl
Concentration is on floor of velo as seen with Daniel.
Strength from rear wheel well, chain canal (the main spar of a velo), bridge between front wheel wells. Your rear bulkhead, like mine gives super strength.
You can make the lateral rear chain wheel housing.
Did you have any weak areas on chain route on last velo, this one will be stronger. I don稚 have any weak areas yet.
覧覧覧覧覧
carolina Posted - 03/09/2018 : 11:37:00
That will work, I would do north and south footprint wider and use the front face of the bridge too. Figure floor flexing like waw did. Front base plate and leading edge of bridge makes a box. You can gusset it too. Top plate by knees wide.
Cf over wood, aluminum bb embedded,(or use Quest sliding bb over a 40mm sq tube)..
You will bolt it in??
___________________
Terry Posted - 03/09/2018 : 10:48:25
Another boom . This better deals with the forces!
Sorry, I can't figure out the photo posting but they might show on my flicker ?
T
carolina Posted - 03/07/2018 : 17:56:08
Yea, 40 mm aluminum or cf. I would go with sq & buy a quest bb. Side it forward or backwards on the 40mm boom. Call theo, he will mail it that day or next. You have aluminum welder guy local.
Ive tacked tubes together with hot glue and let joe alum weld it. Yea
Waw and hilgo pics and large top & bottom footprint.
The bridge is a rock in mine and your too, permanently mounted. Glued in, it痴 a wood box.
Stay on front leading edge of bridge and floor.
Wide footprint at top , it want go anywhere.
Study new waw (pics) bridge,, new waw location is way stronger than it use to be on older models.
If ya haf to make a stronger bridge, no problem.
Terry Posted - 03/07/2018 : 16:17:03
Mike,
There are some images of the Hilgo that look possible.
I will mock up an idea or two! I might have to go with some aluminum?
T
carolina Posted - 03/07/2018 : 13:25:16
Better zoom in terry! Hilgo velo google images and youtube.
Keep the tensioner idea too.
______________
Terry Posted - 03/07/2018 : 11:12:10
Thanks for that Mike, The problem might be that I'm trying to blend the WAW with the df.
Might have to go with side stick ??
I'll keep messing around for awhile till it's not fun!!
T
Terry Posted - 03/07/2018 : 11:01:51
Jerry, Thanks for adding the link.
SB, I get it. Presently the design is poor. I'm here looking for ideas to improve it! Maybe that is not possible?
I can't see a way to get a longer lever back to the seat and still use tiller steering?
I could tie it into the front of the bridge like the mockup but is that enough ?
T
carolina Posted - 03/07/2018 : 10:18:32
Yea, Terry that worked.
Your getting close, maybe run tube back over bridge like waw because tiller dose not need to go Left or Right. That would be bigger footprint & you can have bigger footprint at top too.
Here痴 the photo/zoom in.
_____________
Speedbiker Posted - 03/07/2018 : 08:09:36
Yeah, I told you a straight up and down boom mount wouldn't work. It doesn't address any of the major loads. Even if you double up the carbon it will still be a poor design.
Jerry Posted - 03/06/2018 : 21:09:10
How about this! https://www.flickr.com/photos/146970675@N08/
carolina Posted - 03/05/2018 : 17:41:21
Terry , i still can稚 get it to work. I got arrows punched up but but still two pics. Have looked at flicker pics for years dont inow what iam doing wrong.
Terry Posted - 03/05/2018 : 17:26:24
Tom, yes those are the ones.
T
Tom Schneider Posted - 03/05/2018 : 15:17:30
I can view 39 pics in Photostream in Flickr, are these the pics? I am using Chrome.
Tom
carolina Posted - 03/05/2018 : 11:52:56
Yours has no arrows. Most do! I can稚 work it. Photobucket is kindergarten!
Terry Posted - 03/05/2018 : 09:36:19
hmmm, the Flickr pics are public.
Is there an arrow in the top left corner? Press that to get to the other pics.?
Other than that ,,, I have no idea!
I don't want yet another photo site that I don't know how to use
Email?
carolina Posted - 03/05/2018 : 07:28:44
Originally posted by Terry
Sorry, no..
Does that link not work?
T
No,
Most flickers are open, member would haf to join yahoo.
U sent 2 old pics of your velos.
Can you send boom / bridge photos?
You might wanta use photobucket then you can add what pic you want each time or remove them.
________________
Terry Posted - 03/04/2018 : 23:53:38
Sorry, no..
T
carolina Posted - 03/04/2018 : 17:14:16
Terry, do u have another way to put pics up?
Terry Posted - 03/04/2018 : 15:18:26
I've made a bridge to fit between the wheel wells as well, contain the steering rods and the tiller steering bearing. Next plan is to run a brace from the bridge to near the cranks!
Anyone think this will work or a waste of time?. I am trying to avoid having to tie the end of the boom to the nose cone?
T
