www.recumbents.com - NoCom Tailbox - continued
Page: of 5
Posted - 03/09/2010 :  18:03:38  Show Profile  Visit warren's Homepage  Reply with Quote
So now we have a very pretty and fast looking tailbox plug, and we want to make some fairings. What's the next step? We have to build a female mold. Garrie Hill explained one methods of building the female mold, and is working on documenting it here:
http://www.recumbents.com/wisil/hill/femalemold/
Posted - 03/09/2010 :  18:27:14  Show Profile  Reply with Quote
Thanks Garrie, It looks great. Please provide some tips to finding the equator of the plug and marking it. I was thinking about a rotating laser. What do you think.
Posted - 03/09/2010 :  19:51:53  Show Profile  Reply with Quote
Sean is reminiscing about his nights at the disco.
I am anxious to see page 2.
Posted - 03/10/2010 :  19:30:29  Show Profile  Reply with Quote
Sean;
With the plug laying on its side, sand bagged in to place, visually level the plug. When you do the scribing step, the square will lightly scuff a line around what is (hopefully) the equator. If it doesn't look right, just do over.
I just sent Warren some more steps. I'll have everything to Warren in the next 3-4 days.
http://garriehill.winkflash.com/
and
Posted - 03/11/2010 :  04:44:35  Show Profile  Visit alevand's Homepage  Reply with Quote
In shipbuilding it's called a waterline, though you might have some marital problems if you try this in your bathtub. 6 weeks to Indy.
Edited by - alevand on 03/11/2010 04:48:36
Posted - 03/11/2010 :  07:19:23  Show Profile  Reply with Quote
It would be the waterline if the boat were listing 90 degrees (to the side).
raymondg
Posted - 03/11/2010 :  11:48:22  Show Profile  Reply with Quote
Not just in shipbuilding, but in aircraft manufacturing as well. The standard three reference planes are called Waterline (horizontal plane, abbr. WL), Buttock (or Butt) line (vertical plane parallel to long axis, abbr. BL), and Station (vertical plane through cross sections, abbr. STA). Typically the the symmetry plane is called the "zero butt line" or labeled BL 0.00 (varies slightly from company to company). This is the reference plane you are trying to find. With the Orion, I have two symmetry planes, so I call the horizontal one WL 0.00, which is where I split the top half from the bottom.
I only bring this up because it helps to have a standard terminology for such things when communicating with others, and since I work in the aerospace industry, I am used to one that is already in common usage.
I'm looking forward to seeing those tailboxes. Happy Molding!
Raymond
LongJohn
Posted - 03/12/2010 :  02:46:36  Show Profile  Visit LongJohn's Homepage  Reply with Quote
Raymond,
You make me proud!
Thomas (KLM)
Edited by - LongJohn on 03/12/2010 02:46:57
Posted - 03/12/2010 :  03:36:15  Show Profile  Reply with Quote
Raymond, so in other words, we should make light skid marks on the zero butt line.
Warren, Let me know when you have that finished.
raymondg
Posted - 03/12/2010 :  07:52:43  Show Profile  Reply with Quote
Sean.
Yes. For me personally, I would put a scribe line on the zero butt line with a sharpie held in a tool similar to what Garrie shows, only oriented so as to be a fixed distance off the reference plane (the mdf). Very similar to the tool you made to mark the wheel fairing tire cutouts on the Orion, if you recall, only much higher, obviously. Then I would mark the plug at multiple locations with small dots, where the geometry makes it easiest to know exactly where you want the mid plane to be, such as the trailing edge and the seat area. When you sand bag the plug, tap it into position until all those dots you made are at the same height from the reference plane, and then use your sharpie "scribe" to mark the whole centerplane.
This approach may seem overkill to simply locate the mold flange, and it is, but it serves another purpose. Down stream, when it comes time to cut holes in or mount brackets to your tail box, you now have a very precise reference plane to aid in their location. Simply put the tail box in the mold, and now you have a precise plane that you can easily measure from for any locating.
Raymond
Posted - 03/12/2010 :  08:55:53  Show Profile  Reply with Quote
Raymond;
Probably won't work in the case in point. You are assuming that this plug has bilateral symmetry. I can just about guarantee it doesn't. The plug has been done, redone, finished, and refinished. It WILL have lumps, bumps, waves, and wiggles. Therefore, eyeballing will produce a line that is as good as the plug. Trying for something better will just lead to frustration for these guys (Warren, Allen, Sean, Rick). Believe me, I took all of this in to account when I put these instructions together. Good enough really is good enough in this case. 't'ain't rocket science.
and
Posted - 03/12/2010 :  11:15:33  Show Profile  Visit warren's Homepage  Reply with Quote
Ha I got it Sean.
Posted - 03/12/2010 :  13:37:32  Show Profile  Reply with Quote
Oh. Yes. Well, erm........ me too; but with a slow dawning of comprehension. Har-dee-harr!
and
Posted - 03/12/2010 :  15:45:32  Show Profile  Reply with Quote
I have a picture of James Schroeder from BM 09 with a "skidmark" from his chain rubbing on his shorts.
But it's not that funny.
Posted - 03/12/2010 :  17:05:32  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
And here's where things start going downhill... fast.
Posted - 03/12/2010 :  17:21:26  Show Profile  Visit warren's Homepage  Reply with Quote
Ok, Skreeeeeeeee.....Dragging thread back on topic....
Here's the latest update of Garrie's female mold page:
And, I bought a very heavy chunk of 3/4" MDF.
Posted - 03/12/2010 :  17:23:25  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
Anyway... getting back on topic.
A question for those of you who have built plugs, molds, and other assorted composite thingamabobs:
I understand the process of building a plug, attaching a flange, making the first female mold off of that, making the other female mold off of the other side, and then making the parts in the molds.
But...
Is it possible to make the plug in such a way that you can split it apart after it's finished? That is, the interior structure would be a bunch of right-angle panels so that the plug separates into quarters, allowing easy attachment of flanges and subsequent mold-making.
I can see that it would be easy to damage the edges of the plug once apart, but since these sections are usually dressed up before the part is made I don't see it as much of an issue. Also, the parts are easier to remove from the mold, since the mold is split right in the middle.
Is this practical? Or is it too much work for a simple plug? Is everything dimensionally stable enough that the parts would line up after being pulled from molds made like this?
Posted - 03/12/2010 :  20:28:36  Show Profile  Reply with Quote
You are all welcome for my brand of sophomoric comedy. To make up for my tasteless humor I have some constructive input. I have found that modeling clay can be easily and effectively warmed in the microwave oven without imparting smelliness to your food. It doesn't take too much, so don't overdo it. This is a really great service you are providing Garrie. I am learning new things.
LeeW
United Kingdom
Posted - 03/13/2010 :  01:26:19  Show Profile  Reply with Quote
Would it be possible to provide metric measurements for those of us who don't know what an oz is? Ok I tried converting 2oz to grams and got 56g which sounds horribly light for glass cloth, I don't think such light glass cloth even exists.
I have 300gsm glass cloth and 600gsm. Would they be suitable?
Posted - 03/13/2010 :  06:43:44  Show Profile  Reply with Quote
Lee;
16 ounces (0z)/pound.
.75 oz = .05 pounds
454 grams/pound
.05 * 454 = 21.28 grams per square yard
.836 meters squared per yard squared
17.73 grams per square meter
http://www.onlineconversion.com/
Yes, we start of with very fine, very light cloth. Yes, it is very, gossamer light. Imagine woven spider web!
and
mikeatlbch
Posted - 03/13/2010 :  08:03:09  Show Profile  Reply with Quote
Planes of reference. Wit the things we see and do maybe we should follow the anatomist.
In medicine and anatomy:
http://en.wikipedia.org/wiki/File:Human_anatomy_planes.svg
Coronal Transverse Sagital Median Longitudinal
dorsal ventral caudal cephalad
On the otherhand, pictures can work.
Mike
Edited by - mikeatlbch on 03/13/2010 08:07:35
raymondg
Posted - 03/13/2010 :  09:28:19  Show Profile  Reply with Quote
Yes. The bikes I worked on in college were all full plugs, and I didn't like putting the flanges on so every plug I have made since is split. You can see examples of symmetrical and non-symmetrical split plugs here:
http://www.recumbents.com/wisil/gage/orion_speedtrike2.htm
You can just drill holes through two plug halves and bolt them together if you like. Just use the wonderful non-hardening modeling clay everyone keeps on about to cover the hole when it comes time to lay up the fairing. It can also be used to cover blemishes like a chipped edge, rather than doing another fill and sand cycle.
Regards,
Raymond
Posted - 03/13/2010 :  13:43:44  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
OK- you used a half-plug to create a fairing that's symmetrical top-to-bottom. I was thinking of creating a full plug that would come apart along the waterline and butt planes (thanks for the terminology), add flanges, and take molds off of these "quarter plugs". By bolting pairs of molds together, you'd have a either top and bottom or left-side and right-side molds. (And, in the spirit of a couple Battle Mountain competitors, bolting them all together for a bombproof shipping container.)
As I said- would this work? Has anyone seen this done, much less attempted it themselves?
Edited by - Jeff Wills on 03/13/2010 13:44:21
raymondg
Posted - 03/13/2010 :  14:59:48  Show Profile  Reply with Quote
Jeff, the Orion and the Linear 95 were symmetrical vertically, but Great White was not. If you look closely at this pic, you will see both halves of the plug:
In this case it was split left and right at the zero butt line. If I understand you correctly though, you want to split yours into quarters, which I have not done, but would be little different in execution. IIRC some Varna molds split three ways: a bottom, and two top halves, with a non-planer split surface between the bottom and the two tops. Georgie is God and I think he just puts flanges wherever he thinks best and they turn out practically perfect, but the rest of us have to resort to other more time consuming methods.
Raymond
Edited by - raymondg on 03/14/2010 08:36:03
Dreamer
Posted - 03/13/2010 :  19:45:57  Show Profile  Reply with Quote
The new one piece molded seat fixes that problem. We used James as the plug and the short line transferred into the mold but we've got that fixed.
Posted - 03/13/2010 :  21:27:52  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
In this case it was split left and right at the zero butt line. If I understand you correctly though, you want to split yours into quarters, which I have not done, but would be little different in execution. IIRC some Varna molds split three ways: a bottom, and two top halves, with a non-planer split surface between the bottom and the two tops. Georgie is God and I think he just puts flanges wherever he thinks best and they turn out practically perfect, but the rest of us have to resort to other methods more time consuming methods.
Raymond
Yeah, I got up to my armpits building the OHPV Varna clones. It's as you describe: top is two halves, roughly 1 arm-length deep (which is why I got to squeegee the head section- I had the longest arms!) while the bottom pan is one piece. I was thinking that if the lower fairing got to be deeper and a more complicated shape, a vertically split mold would make extraction easier.
Page: of 5 Previous Topic Topic Next Topic
