www.recumbents.com - 55 mm front hub
 55 mm front hub
AlanD
Posted - 06/04/2012 :  13:27:53  Show Profile  Reply with Quote
I have an M5 with a narrow front fork.
The wheel hub is 55 mm.
I would like to try building my own front wheel.
Any one know a good source for something like this?
Thanks.
Posted - 06/04/2012 :  13:58:40  Show Profile  Reply with Quote
source for determining spoke lengths? buying spokes? selecting/buying a rim?
AlanD
Posted - 06/04/2012 :  17:22:21  Show Profile  Reply with Quote
A source for a 55mm hub.
airxxxwolf
Posted - 06/04/2012 :  17:42:51  Show Profile  Reply with Quote
Hey Alan,
I can make a 55mm hub.....how many do you want?
Don
BBM Racing Components
bbmracing@yahoo.com
Posted - 06/04/2012 :  18:55:58  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
Originally posted by airxxxwolf
Hey Alan,
Don
bbmracing@yahoo.com
I'm pretty sure Don or M5 will be your only source. There were some 80mm width Mavic hubs made, but they were rare as hen's teeth back when they were being manufactured:
http://www.velobase.com/ViewComponent.aspx?ID=C4CED345-E01F-4AEB-A0A9-BB372EB9A998&Enum=110&AbsPos=7
Posted - 06/04/2012 :  22:31:32  Show Profile  Reply with Quote
I had to rebuild my M5 451 wheel... and late model 55mm hub uses non-bent spokes. So I ended up ordering set of spokes from Bram@M5.
What's good in this spesific hub:
  • It is ultra-light. No excess metal anywhere
  • It has lubrication nipple. Might be handy if using bearings which have only outer dust cover
  • Seems to be very durable.
What I don't like:
  • 15mm axle is solid steel. Too heavy. I'm considering fabricating hollow one from 7075 aluminium or carbon...
  • When in need for spoke replacement bearings must be removed (as bearing locks spokes in place which is on the other hand good for not loosing those totally if nipples unthread as did for me)
  • Bearings will get loose. I had to use thread locking compound to keep my previous SKF bearings in place, and now SKF E2 bearings are loose, again.
I'm assuming AlanD does axle himself and uses normal fork instead of monofork for which 55mm hub's been designed. Will be easier as fabricating hollow 15mm axle is not hard, aka Hope which uses end caps to fit hub to normal 10mm road dropouts (among other dropout types).
MetaPhysic 700c @ 2011, M5 CrMo Lowracer @ 2010
AlanD
Posted - 06/05/2012 :  01:08:56  Show Profile  Reply with Quote
1. Don: I will contact you directly.
2. mhelander: Thanks. How many spokes does your front wheel have?
Posted - 06/05/2012 :  01:58:09  Show Profile  Reply with Quote
Mine has 28 radial 2mm spokes.
Edited by - mhelander on 06/05/2012 02:01:18
Posted - 06/05/2012 :  04:19:25  Show Profile  Visit alevand's Homepage  Reply with Quote
There are applets on the web to determine spoke length, just Google it.
AlanD
Posted - 06/07/2012 :  12:43:21  Show Profile  Reply with Quote
I contacted M5... and Bram said he can provide these hubs. I was only wondering if there was an
alternate source.
Thanks for the advice.
Posted - 06/07/2012 :  22:24:22  Show Profile  Reply with Quote
alternate source.
I would be surprised if there's another source. Please keep me/us updated if there's one...
Posted - 06/08/2012 :  20:33:35  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
Bike Friday sells a narrow front hub:
https://bikefriday.com/thestore/product_info.php?cPath=26&products_id=12802
but they don't specify how narrow. I bet Rob English would know.
Edited by - Jeff Wills on 06/08/2012 20:33:52
Runxner
Posted - 06/09/2012 :  01:56:11  Show Profile  Reply with Quote
Looks like 74mm http://www.ebay.com/itm/Phil-Wood-74mm-Brompton-Bike-Friday-Tikit-hub-silver-/140765657279?pt=Cycling_Parts_Accessories&hash=item20c64978bf
Team Low-Life
Lowracer Test Pilot/Evangelist
Adelaide, Australia
Posted - 06/09/2012 :  04:50:31  Show Profile  Visit alevand's Homepage  Reply with Quote
I made this one yesterday: 2 1/4 inches nut to nut.
Still need to trim the axle down.
Is radial lacing dangerous on an old hub?
Posted - 06/09/2012 :  09:16:48  Show Profile  Reply with Quote
Only if it is bonded together... Ha ha.
Posted - 06/09/2012 :  11:50:42  Show Profile  Visit alevand's Homepage  Reply with Quote
Good, since it's press fit together.
Posted - 06/09/2012 :  13:06:04  Show Profile  Reply with Quote
To maximize hub's stability I would at least lace it 1-cross minimum. Crossing spokes doesn't add that much spoke length and thus weight.
Use Double butted spokes, for example, DT-Swiss revolution 2.0/1.5 with aluminium nipples, if saving weight.
Posted - 06/09/2012 :  19:30:14  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
In general, yes. The old spokes will have created divots in the old shell where the bends lay. Also, older hubs weren't designed for radial lacing and thus have less material from the spoke hole to the edge.
A while back I laced a wheel to an old Shimano high-flange hub in a crow's foot pattern- 2/3 tangential, 1/3 radial. After a couple months, the hub was cracked at the radial spokes, all the way around.
That hub, if it's never been laced before, might be OK. I wouldn't take the chance, though- if the flange breaks, bad things happen.
Posted - 06/10/2012 :  06:27:58  Show Profile  Visit alevand's Homepage  Reply with Quote
I thought about a cross 1 pattern, and it would work with the same length spoke. The cross was halfway out from the hub. The angle didn't look like it was gaining much hub thickness, but then again, metal fatigue is logarithmic. The bend in the spokes might make the wheel more compliant. The radial pattern is much stiffer than the last wheel I laced with cross 3 double butted spokes. I think butted spokes would be best too for this wheel. I had these spokes from a 26 inch wheel and thought I'd try them, since the radial pattern would maximise the lateral stiffness of the narrow hub. It looks cool.
... I changed some spokes to cross one.. It really puts too much bend in the spoke.
I'll have to order some butted spokes for cross 2 pattern.
Edited by - alevand on 06/10/2012 07:33:52
Posted - 06/10/2012 :  07:45:42  Show Profile  Visit warren's Homepage  Reply with Quote
Tony,
In your cross pattern you have the outside spoke crossing under the inside spoke, that's why you have too much bend.
Posted - 06/10/2012 :  08:51:36  Show Profile  Reply with Quote
Is Warren suggesting that one should not interlace spokes in a 1X pattern? Because the cross is too near the hub?
(I've never made a 1X wheel. All of mine are 2X or 3X so the cross where I interlace is further away from the hub and the bend in the spokes near the hub is not so severe.)
Edited by - Larry Lem on 06/10/2012 08:53:44
Posted - 06/10/2012 :  08:59:26  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
A lot of that bend will go away once the spokes are tensioned, stress-relieved, and tensioned again. However, I agree with Larry- 2X or 3X isn't that much heavier, and the safety margin of the wheel goes way up.
Posted - 06/10/2012 :  09:10:19  Show Profile  Visit alevand's Homepage  Reply with Quote
Jeff, those are tight, but not stressed.
It doesn't look too bad when the spokes are not interlaced, it's about a 30 degree tangent angle.
Edited by - alevand on 06/10/2012 09:23:51
Posted - 06/10/2012 :  12:13:55  Show Profile  Visit Jeff Wills's Homepage  Reply with Quote
Once you're done tensioning and stress-relieving, the spoke just after the bend will be in contact with the flange. If they aren't, the bend will flex with the cyclical loading it gets while the wheel rolls. This will fatigue the bend and cause premature failure.
